fifo shared variable programmatic access
Good evening!
I have a question regarding programmatic access of shared variables.  I understand that to
change the IP Address of the remote computer "on the fly", I need to replace shared
variable nodes with programmatic access 'Read Variable' and 'Write Variable'.  I have done
this for network-shared variables that have aliasing enabled.
For network-shared variables that also have RT FIFO enabled, the option for replacing with
programmatic access is disabled.  I manually replaced the nodes with 'Read Variable',
but nothing happened.
Does anyone have a suggestion?  I am using the RT FIFO's (one for timestamps and
another for an array of 97 data values) to monitor measurements from a Compact RIO on
a Windows PC.
Hamilton Woods
Message 1 of 9
(5,000 Views)
Update:
I have had a suggestion to consider using network streams instead of RT FIFO network-shared variables.
I am desiring to pump timestamp and measured data to a Windows PC from a Compact RIO.
Any other suggestions for how to do this?
Any areas of concern for using network streams?
Hamilton Woods
Message 2 of 9
(4,964 Views)
Hi Hamilton_Woods,
If the timestamp is part of the array you'll be sending over the network stream, then a network stream would be fine to use to send your data.  I'm unsure why you can't replace an RT FIFO with programmatic access, I'll look into this further.
Bobby Breyer
Applications Engineer
Message 3 of 9
(4,957 Views)
Bobby,
Any discoveries regarding programmatic access of RT FIFO network-shared variables?
Hamilton Woods
Message 4 of 9
(4,940 Views)
Hi Hamilton_Woods,
We're still looking into this internally.
Bobby Breyer
Message 5 of 9
(4,929 Views)
Hi Hamilton_Woods,
It looks like you can still programmatically do this, however the functionality to drop a Network Shared FIFO then replace it with programmatic access is disabled.  I'll go ahead and file a request on this.  Thanks for the heads up!
Bobby Breyer
Message 6 of 9
(4,917 Views)
Bobby,
I already attempted to perform a programmatic access of the RT FIFO by using the read shared variable
function in the same way that I am using it to read other shared variables.  It doesn't work for me.
I intend to replace the RT FIFO shared variables with network streams when I get a chance.
Thanks for your help,
Hamilton Woods
Message 7 of 9
(4,910 Views)
I come across the same question: programmtic acess to FIFO shared variable.
It doesn't allow to do this in LV2014.
Any update?
Yan
Message 8 of 9
(4,807 Views)
Hello Yan,
It seems that this thread is quite old and kind of out of place.  Would you mind creating a new thread for this question in the LabVIEW RT Forum?
Thomas C.
FlexRIO Product Support Engineer
Message 9 of 9
(4,788 Views)
