fgv with two types of variables
Do you really need the First call contruct at all? If the program is fresh the array is empty and the 1st Set will add to the empty array, no?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 26
(1,122 Views)
Nope, I don't need the first call construct, I've used the feedback node to initialize.
Trusting altenbach, it will be initiated during the first call to the "set" (store) action.
This is what I'm going with for now. (until my lecturer tells me I'm wrong or doesn't allow me to use this 🙂 )
Message 22 of 26
(1,119 Views)
It is needed to define the datatype of the shift register (Of course there are other ways around this).
Message 23 of 26
(1,109 Views)
Just a little update:
been to see the lecturer today and he told us that in our case it would be best to use a 3rd state of init which would allow to reset the FGV if needed.
Also advised to use a SR instead of a FBN since it would be "easier to understand"...
Message 24 of 26
(1,106 Views)
Yeah i'd say that's a more common approach.
/y
Qestit Systems
Message 25 of 26
(1,091 Views)
I think this is what you looking for, in this VI there are 2 arrays in 1 cluster and which has the control for separately adding the DBL to any of the array and you have selection control to extract any of the 2 array at the output array.
Message 26 of 26
(1,005 Views)
