fetch combo box value
I have a long SQL string, in which a user selected value from a combo box should be passed in several lines.
I could use Concatenate to combine the combo box value with other part of SQL string but since the string is long and the combo value is supposed to appear several times in between I want to preferably avoid this method. Is there any way to catch the combo box selected value in a text way programming so to I give it in the SQL string?
Cheers
(1,662 Views)
Hi Hasamon,
  • What about providing an example (VI) with some input values and an expected output value?
  • What's wrong with ConcatenateStrings?
  • What is "catching a combobox value"? Do you mean to read the combobox by using a wire from its terminal?
  • What is a "text way programming"?
  • What about using FormatIntoString to format a string?
(1,654 Views)
This just screams "Use Format String" to me.  You can use something like "%1$s" to repeat using the same input (the first value in this example).
(1,645 Views)
Thanks, I was looking for something like this. But using this format, where should I replace my input?
Could you elaborate it a little bit?
For example, given the below query:
SELECT
From dbo.RESULT
WHERE RESULT.Value1 > X
If I want to pass value X as an input, how should I rewrite this string?
(1,574 Views)
You just replace the "X" with the format.  Assuming your value is an integer, your example string would just be:
SELECT
From dbo.RESULT
WHERE RESULT.Value1 > %d
(1,543 Views)
