Multiple case selection at a time
I have 3 cases for example case 0, case 1, case 2. i want to select multiple cases at a time  such as case 0,1,2 at time, 0,1 at a time,1,2 at time Etc etc. i have gone through some examples and got to know its not possible to select the multiple cases at time. Can someone give me an idea how can i do it??
Message 1 of 37
(3,972 Views)
Hi jeet,
i want to select multiple cases at a time  such as case 0,1,2 at time, 0,1 at a time,1,0 at time Etc etc.
How do you want to select "0,1,2" or "0,1" or "1,0"???
What's the difference between calling "0,1" or "1,0" "at a time"???
How do you determine which cases to execute "at a time"???
Do they really need to run in parallel???
Message 2 of 37
(3,963 Views)
hi,
for question 1 and 2. i want to select case using boolean push button. moreover  i want turn on all three or any two at time or only one.
3. yes.
 thank you
Message 3 of 37
(3,957 Views)
@User002 wrote:
hi,
3. yes.
 thank you
How about posting an example of what you are working with that does not work and we could help make it work.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 4 of 37
(3,943 Views)
Hi jeet,
When there are 3 buttons then use 3 case structures...
Message 5 of 37
(3,931 Views)
Should up to three cases run truly in parallel or would it be sufficient to execute them sequentially? What do the various cases actually do?
Message 6 of 37
(3,921 Views)
how to select mutiple cases at time? i have some cases such as case 0 case 1 case 2. i want to select some time indusually, some time 0,1 or 0,2 or 1,2 etc or all three at t time.. is it possible?
Message 7 of 37
(3,846 Views)
Hi jeet,
why do you need to start the same discussion again (after more than a month)?
Message 8 of 37
(3,839 Views)
i still did not get answer of it
Message 9 of 37
(3,824 Views)
You should never select anything "indusually"; that's way too cromulent.
Message 10 of 37
(3,812 Views)
