failed to load dynamic library
By mistake I loaded the .abc file in .vi file when it asked to select the path for the OCR character file.
Now I'm getting the error failed to load dynamic library when I try to open VI file.
Please suggest the solution.
Jasraj Rajpurohit
Jasraj Rajpurohit
(4,455 Views)
Hi Jasraj,
This post is extremely vague. It would be very helpful if you could post some information about your application (what is the application's intent, what hardware are you using, etc.) and also post your code. Based on the fact that you said "OCR character file", I am assuming you're referring to an Optical Character Recognition file, so I would guess you're doing some sort of computer vision reading application, but that is just a guess as you haven't provided any information on your application nor the hardware you are using.
(4,417 Views)
Accepted by topic author jasrajrajpurohit
Hi Andrew,
Yes your guess is right.
The VI file has been corrupted. As there is no solution for such problems until and unless we have backup file.  (Discussed with NI India)
Jasraj
Jasraj Rajpurohit
(4,406 Views)
So revert the VI from SCC. If you don't have SCC, well, lesson learned.
If it's an NI\LabVIEW\Toolkit VI, we need at least the exact name of that VI.
(4,398 Views)
