extracting columns from 2D string array according to first element of each column
I have a 2D string array and I want to extract columns from it according to the string value of on of the elements in each column to formulate a new 2D array. for example:
in the attached excel sheet a 2D array. I want to extract the whole columns contain "CA/S-" string and "MS/S+" to formulat another 2D string array formed of the columns that contain only those 2 string values.
Thanks a lot and I would reaally apperciiate any input 🙂
Cheers,
Mostafa
Message 1 of 11
(6,881 Views)
Accepted by Nashaat
Something like this?  I had to convert your Excel file into a CSV.
Message 2 of 11
(6,877 Views)
If performance is a concern, here's a solution that operates "in place". Modify as needed.
Message 3 of 11
(6,860 Views)
Thanks a lot. That's exactly what i was looking for Smiley Happy
Message 4 of 11
(6,813 Views)
Dear Mr. Altenbach,
I'm a beginner in using LabVIEW with datafile.
It would be usefoul for me to have the vi code of your example so I will have a starting point for work on my application.
I need to sure identify the used function to avoid misfunction due to wrong connection for the starting point.
Thak you a lot in any case.
Best regards.
Message 5 of 11
(6,694 Views)
Transpose array, index array, replace array subset, array subset.
For loop, case structure, shift register.
Try it!
Message 6 of 11
(6,677 Views)
If you want code, you need to tell us your LabVIEW version.
If you have a recent version, you can use a conditional tunnel to simplify the code even more. (see attached 2014 version).
Message 7 of 11
(6,668 Views)
Thank you for your suggestion, I find a way using a similar solution.
I'm using LV 2011.
Best regards.
Message 8 of 11
(6,659 Views)
I'm using LV 2011.
LabVIEW 2011 does not have the conditional tunnel.
Message 9 of 11
(6,656 Views)
Try it!
Sorry, I was referring to your first suggestion.
Best regards.
Message 10 of 11
(6,652 Views)
