external reference arduino
Hi guys,
I'm using Arduino with LabVIEW (LIFA). But I have some problems, I'd like to convert this sketch in LabVIEW:
int XPin = A0; // X
int YPin = A1; // Y
int ZPin = A2; // Z
void setup() {
  Serial.begin(9600);
  analogReference(EXTERNAL);
  Serial.println("Setup ADXL377Z");
void loop() {
  int xAccel;
  int yAccel;
  int zAccel;
  Serial.print("X: ");
  int x=analogRead(XPin);
  Serial.print( x );
  Serial.print(" Y: ");
  int y=analogRead(YPin);
  Serial.print( y );
  Serial.print(" Z: ");
  int z=analogRead(ZPin);
  Serial.print( z );
  Serial.print("\n");
  if(x >= 513){
    xAccel = map(x, 513, 1023, 0, 200);
  } else {
    xAccel = map(x, 0, 513, -200, 0);
  if(y >= 511){
    yAccel = map(y, 511, 1023, 0, 200);
  } else {
    yAccel = map(y, 0, 511, -200, 0);
  if(z >= 515){
    zAccel = map(z, 515, 1023, -1, -200);
  } else {
    zAccel = map(z, 0, 515, 200, -1);
  Serial.print(xAccel);
  Serial.print("G, ");
  Serial.print(yAccel);
  Serial.print(zAccel);
  Serial.println("G");
  delay(1000);
But I don't know how I can set the external reference and how I can implement the "map" comand.
Do you have some advices?
Message 1 of 10
(6,019 Views)
I'm not sure what the purpose of the external reference is but LIFA can just read an analog.  You also may want to consider using LINX since LIFA is getting a bit dated and hasn't been updated recently.
As for your scale range checkout the VI in vi.lib
vi.lib\Utility\Range And Ratio.llb\Scale Value to New Range.vi
I think this is the same function where it will remap a value to a new range.
Message 2 of 10
(5,972 Views)
try to have a look at LabVIEW interface for Arduino.
Regarding "map" function, you can try to use LabVIEW Express VI Scaling and Mapping.
I hope it helps!
Bye,
Licia
Message 3 of 10
(5,965 Views)
For the reference, you would have to modify the sketch to read a command sent by the LabVIEW program that sends the type of reference you want.
Message 4 of 10
(5,963 Views)
Hi thanks,
I've used Linx and now it works very well Smiley Wink
Message 5 of 10
(5,953 Views)
I don't remember off-hand whether LINX or LIFA supports setting the analog reference mode, but if not, all you need to do is to customize the firmware slightly, by placing that
command in the setup() function of the firmware. You'll need to duplicate the firmware file first (for LINX, the files live in Arduino/Libraries/LINX/<board name>/<board name.ino>). Make the one change to the function, and then upload the revised firmware to your board.
If you anticipate changing reference modes in runtime, LINX supports custom commands, and it would be pretty straightforwad to write one that recieves a byte from LV, parses that byte, and sets the reference mode accordingly.
Message 6 of 10
(5,946 Views)
LIFA does not, I don't have LINX installed at the moment but I doubt it has it.  Might be a good feature request if this is a common thing.
Message 7 of 10
(5,933 Views)
I went and checked; LINX does come with a routine for changing the reference mode (and reference voltage value). So, the solution is just use LINX and use the built-in function.
Message 8 of 10
(5,916 Views)
Could you define how you solved the problem?
I have the same problem, but I can't find the solution somehow!
Thanks in advance!
Message 9 of 10
(2,597 Views)
