external Application
how can i start an external Application (.exe) from LabView
(3,644 Views)
jus an example for your reference
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,644 Views)
Thanks, thats exactly what i need !!!
(3,644 Views)
Try "System Exec.vi"
bye
Marco
(3,646 Views)
How can you STOP the application you started, using labview?
George
(3,456 Views)
Hey George!
There might be a few ways to do this, but if you are using the system exec VIs you will have to know if the application accepts any command line arguments.  This may allow you to quit your application using the system exec VIs.  A much better solution would be to make calls into the Windows API and close applications this way.  There is a toolkit available that will allow you to do this, linked here.  Let me know if this works for you!
Hope this helps!
Andy F.
(3,436 Views)
