exporting labview vi for 8510 to visual basic
Hi all,
I wrote an application for 8510A IN LabVIEW, I want to export the labview vi to visual basic or C++. Can I do this?
How do I specified the device address? I appreciate it if there is any example for reference.
(2,531 Views)
You should search for converting VI into DLL (also called Shared Library) and then you can use that in VB or C++.
For you refernece, find below links:
1. Distributing Applications with the LabVIEW Application Builder
2. Using Build Specifications
3. Building a Shared Library
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,521 Views)
