Motion control with third party PCI card and LabVIEW
Hello everybody!
I have an application to control motion of servo motor with LabVIEW and third party PCI card (DMC2410 - Leadshine make).
I have interfaced servo drive with PCI card and PCI card with PC. started with a basic application and its working fine.
In the attached screen shot i'll give set position in 'mm' after press 'start; button motor will rotate.
Now i have to set profile from excel sheet instead of a Numeric Control.
So how can i replace the set position Numeric Control with profile(excel) selection control.
(3,178 Views)
You can implement the code in pieces and essentially there should be 2 pieces:
1. Reading EXCEL profile (series of set-points)
2. Controlling motor to set the positions (set-points)
Now where exactly are you facing problem, as you already specified
that there is no problem in communicating with the motor.
For implementing 2 point (Controlling motor to set the positions), probably you can keep the motor controller driver (VI) in 'Autoindex enabled' For loop.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,166 Views)
Both of them.
First, it should accept the series of setpoints from excel, and then motor have to act with respects the to the set points.
(3,158 Views)
The attached picture (names as Block dia.jpg) is actually a snapshot of Front panel...!!
Can you post your code and also the format of setpoints file, that is your excel file itself.
(3,149 Views)
Yeah, you can download the VI and DMC 2410 library from following link.
http://www.mediafire.com/?mzljo8889o47nr3
**you have to copy the "DMC2410" library folder into following path to open the VI with out errors.
C:\Program Files\National Instruments\LabVIEW xxxx\user.lib
set point profile will be two columns (time and displacement) of any random values for now.
Plz modify the VI.
(3,138 Views)
Please suggest solution for this. Let me know if you need any inputs from me for better understanding.
(3,113 Views)
