exp() function problem
Hi, I tried to use exp() function in my DLL code. but it cannot be deployed on the RT system. the connection is lost during the process. does anyone know the reason?
Message 1 of 8
(6,638 Views)
Hello machman,
Are you able to successfully deploy a simple .dll on your RT system? Does it fail to deply only when you add the exp() function to your .dll? Moreover, you mention you lose connection. Is there any error message that is associated with this? If so, what is it?
These details may help us find the culprits to this issue.
Cheers,
Emilie K | Applications Engineer | National Instruments
Message 2 of 8
(6,582 Views)
Hi,Emilie, I have successfully deployed some other programs with DLL before. I am not quite sure where the error message is. is it under the directory: c:/ni-rt/system/errors? Thanks.
Machman
Message 3 of 8
(6,566 Views)
I think Emilie means an error popping up while you are deploying.  While you are deploying, you should see a status bar.  Do you see an error, or a popup notification that the connection was lost?
With all other things equal with your application, can you remove the exp() and have things working?
What platform is your RT target?  (PXI, cRIO, FieldPoint, Phar Lap ETS, RTX, PCI boards -- these are really old)  What version of LabVIEW Real-Time do you have?
Are you able to deploy any math related libraries?
Trey B
Applications Engineering
Message 4 of 8
(6,485 Views)
Hi, Trey, the deploying process stops during transferring my application vi. the only message popup is "waiting for RT to respond", then the connection is lost. I tried to delete the exp() function in my DLL code, then the deploying process is successful. I tried "sqrt()", no problem at all. my RT system is PXI 8186 with PXI 1045 chassis. labview RT version  is 7.1. Thanks.
machman
Message 5 of 8
(6,483 Views)
Hi Machman,
If your code is making function calls that are not included in the Win32 subset that the real-time operating system has, then the code will fail.  Please take a look at the following KnowledgeBase article.  There is a tool that you should run to verify whether or not this DLL will run on the real-time OS.
How Can I Verify that My DLL is Executable in LabVIEW Real-Time?
Message 6 of 8
(6,277 Views)
Thank you, Elizabeth. I will let you know the result. Have a good weekend.
machman
Message 7 of 8
(6,245 Views)
I used MS VC6.0 to generate the DLL. now everything is fine. Thanks.
machman
Message 8 of 8
(5,249 Views)
