Online shopping is currently unavailable.
Please contact us for help or try again later.
09-25-2007 12:27 PM
09-26-2007 12:55 PM
09-26-2007 02:34 PM
Hi,Emilie, I have successfully deployed some other programs with DLL before. I am not quite sure where the error message is. is it under the directory: c:/ni-rt/system/errors? Thanks.
Machman
09-27-2007 11:04 AM
09-27-2007 11:12 AM
Hi, Trey, the deploying process stops during transferring my application vi. the only message popup is "waiting for RT to respond", then the connection is lost. I tried to delete the exp() function in my DLL code, then the deploying process is successful. I tried "sqrt()", no problem at all. my RT system is PXI 8186 with PXI 1045 chassis. labview RT version is 7.1. Thanks.
machman
09-28-2007 12:43 PM
09-28-2007 03:00 PM
Thank you, Elizabeth. I will let you know the result. Have a good weekend.
machman
10-18-2007 01:03 PM
I used MS VC6.0 to generate the DLL. now everything is fine. Thanks.
machman
