execution sequence
Hi all,
I have three case structure.
I want to define the execution sequence as shown in the following ex .
Please help its urgent
Message 1 of 9
(5,171 Views)
Hi Cool : ASDF,
you can do it with a state machine. You need only one case structure for it. Create a case for each of your actions.
Mike
Message 2 of 9
(5,169 Views)
Thanks for quick reply
I dont know basics about state machine, can u provide one example how to implement my code.
actually i dont have that much time to understand about the state machine,
as i have to provide it to customer.
thanks
Message 3 of 9
(5,159 Views)
is it your homework for tomorrow?
For more information on this, see the example finder.
Mike
Message 4 of 9
(5,146 Views)
Cool,
Just type in 'State Machines' in NI's website search bar, there must be hundreds of examples already available. If you dont have time to learn about a state machine then your 'customer' should get his 3 execution software written elsewhere.
"Everything should be made as simple as possible but no simpler"
Message 5 of 9
(5,137 Views)
You should start with this KB article: Application Design Patterns: State Machines.
Message 6 of 9
(5,114 Views)
The quick and dirty solution is to put them in a sequence structure to force execution order.
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 9
(5,095 Views)
Implementing your sequential state machine now will save you time in the future, so I would suggest doing it now also if you look at the VI from template at the start screen for labview you can go down to Standard State Machine and it will give you a basic state machine to start with
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 8 of 9
(5,077 Views)
I'm surprised to see this suggestion but please do not follow this advice. LabVIEW is a dataflow language, not a traditional sequencial language. If you follow this advice you will not be able to harness the full power of dataflow programming. Please take some time to learn the basic concepts of dataflow programming. State machines are very easy to implement in LabVIEW and they are a fantastic programming model. As suggested by Harold earlier in this thread take the time to learnhow to use them. It will pay off many fold in the future.
Message Edited by Mark Yedinak on 03-29-2010 08:23 AM
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 9 of 9
(5,044 Views)
