executable file run on other computers
If i have a program that works, can i create an executable file that will run on another machine without installing labVIEW?
(3,288 Views)
If you have LabVIEW professional  or higher (or the application builder), you can create standalone executables. They only require installation of the free run-time engine on the target machine.
(See also
Message Edited by altenbach on 04-05-2010 04:55 PM
(3,280 Views)
Altenbach is correct, you need the application builder in order to do this.  Go to the Developer Zone Tutaorial: Distributing Applications with the LabVIEW Application Builder for step by step instructions on how to use the application builder.
(3,232 Views)
The comment about installing LabVIEW runtime is a bit misleading though, it is a rather large file. Much has been said negatively about this, versus Visual C, etc., but the trick with them is that MicroSoft installs the runtime for them when Windows is installed.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,211 Views)
