executable file. Exe
Hello .. I'm starting to work with Labview, so I need help.
After creating an executable file. Exe
When I create an application for a client .. what software to install on your machine just to run the application?
Gratefu
Rafael Nunes
(2,884 Views)
Accepted by Nunes
You will need the runtime engine for LabVIEW that matches the version of LabVIEW that you used to create the .exe.
You may also need the VISA run-time engine (if you are doing serial ports, or other VISA based communication).  Also DAQ drivers if you are doing any data acquisition.
(2,880 Views)
