exe contains python node
Hello:
I'm having trouble generating an exe that contains a python node.
My source program works fine, but when I turn it into an application, I get an error in 1663:vi?? . I did some checking to narrow down the scope, and found that the same error will be reported when vi programs only include open python callback programs. Whether can i think of it as opening a python session is an error. How exactly can we solve this? What are the considerations for vi to generate an exe containing python node?
Looking forward to your reply, thank you very much!
(3,373 Views)
Accepted by topic author hallo77
These articles would be helpful
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wzGfCAI&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHmyCAG&l=en-US
Santhosh
Soliton Technologies
(3,360 Views)
Thank you for your reply, but at the moment I am still getting an error when running the generated exe on the development computer.It's very confusing.
(3,349 Views)
Thank you very much. My problem is solved. But I had a new problem. When generating the installer, can I add the libraries that python needs, such as pyserial, to the installer?
(3,323 Views)
You can include the "whl" files for the libraries, you can create a post-install script to call "pip install" after the installer installs Python.
Santhosh
(3,274 Views)
Thanks for your reply. I would have a try.What I would prefer is to be able to self-install even when offline. That might be a little difficult.
(3,255 Views)
