Logging to data to Excel every few seconds
I am using the RTD Thermistor example and trying to log into into Excel.
Its logging the data correctly for all 3 thermistors, however its logging data every millisecond. I would like to have it log every few seconds. I have it set for 10 seconds but it doesn't respond to any setting I give it.
I Have done this using LINX and Arduino and it works fine, I am using a USB 6009 DAQ now and I am not able to control the data timing to the spread sheet the same way.
It does send the data to excel accurately but just way to often.
I have attached the VI.
Brian
(1,422 Views)
Accepted by topic author BrianVod
Solved, it was in the samples per loop. It was set to high.
(1,386 Views)
