exception occured within the external code called by a call library node.
error at node 0x5a8 of spline interpolation.vi
(3,277 Views)
Sean,
Thank you for this information. I would like to request that you post a little more information on your issue. What version of LabVIEW are you running? What is your computer like? Is your problem reproduceable with only one set of data? Does it do this every time you run this VI? What kind of answers would you like from this forum? What can we do to help?
Randy Hoskin
http://www.ni.com/ask
(3,277 Views)
The error was occurring with an exe file that was generated with LV 6.1. It did not occur on the computer that was used for developing the vi but it did occur on all machines trying to run the executable. It occurred even within the backup copies of the program. I uninstalled LV and did a complete reinstall and the problem has gone away. I believe that somehow the LV code was corrupted.
(3,278 Views)
I get this error when I run it on my NI PXI system. I have been looking at all the postings related to this, but I have yet to find a good solution on how to solve this problem. It works fine on the comp, but when I am using it on the PXI system, I always get that error message.
(3,080 Views)
Nevermind, I figured it out. It turns out that one of the parameters I used is not compatible in version 6.1 as it is in 7.1.
(3,067 Views)
