Delete Numbers from Array
i want to create a VI which does something what sound easy but i cant find out how to do it:
Input-Parameter:
1. Numeric Array_in (Int32)
2. tolerance (Int32)
Output Parameter:
1. Numeric Array_out (Int32)
For example:
Input:
Tolerance: 10
100
200
201
300
109
400
405
0
900
Output:
100
201
300
109
405
0
900
The VI should remove all numbers from the array which are equal (plus/minus the tolerance set by the second input parameter).
But: Only numbers which are next to each other should be removed. As you can see in the example there are two pairs of equal numbers +/- 10%: . There is 200&201 and 400&405. The VI sould remove the first number of a pair if they are equal.
Any idea how to solve this problem?
Thank you very much for your help.
Message 1 of 11
(5,356 Views)
What happens when there are more than one in a row like the following...
Input:
Tolerance: 10
100
105
109
110
120
115
What would happen in this case?  Would it be:
100
105
109
110
120
115
Message 2 of 11
(5,347 Views)
Input:
Tolerance: 10
100
105
109
110
120
115
100
105
109
110
120
115
Message 3 of 11
(5,347 Views)
Input:
Tolerance: 10
100
105
109
110
120
115
100
105
109
110
120
115
Message 4 of 11
(5,347 Views)
Input:
Tolerance: 10
100
105
109
110
120
115
100
105
109
110
120
115
Message 5 of 11
(5,347 Views)
Input:
Tolerance: 10
100
105
109
110
120
115
100
105
109
110
120
115
Message 6 of 11
(5,348 Views)
OMG!
My freaking keyboard got stuck... im sooo sorry.
Being able to remove a post within 1 minute would be a nice option!
Message 7 of 11
(5,347 Views)
Use something like in the attached. (LabVIEW 7.1).
(Since percentages are a little tricky with integers, I am looking at the absolute difference instead.)
Message 8 of 11
(5,343 Views)
Hello Chaos,
thanks for that hint but this case will not occur.
Message 9 of 11
(5,329 Views)
Hello altenbach,
thx for the vi. Works great with the absolute value.
Its not a must that its an Integer-Array. Do you know how to do the percentage-thing with doubles?
Thx
Message 10 of 11
(5,327 Views)
