excel template with executables
Hi
I'm having some troubles to recall a template file from an executable
I'm using the output report toolkit to create an excel file with the data i get from the VI. Basically, i have created a template and i call it every time the script runs. It works all correctly if a use a separate VI. When i create a project to build an executable, the same template file is not found by the executable. I've tried to put this template even inside the project but i couldn't make it work (in this later case i dont know the address to assign to the template)
Thank you for your time
(3,160 Views)
Hi Vaso,
how do you select the path to the template? If you build an application the path can change a little bit. Bear in mind that all vi´s lie side by side in an executable.
Hope it helps.
Mike
(3,159 Views)
Initially, i just created the executable and let unchanged the path (the template was still there_see attachment). Then i tried to include the excel template in the project and tried to insert the address that the file would have inside the project. Still didnt work
(3,152 Views)
Hi vaso,
please see this link!
Hope it helps.
Mike
(3,140 Views)
Thanks a lot for your help
(3,125 Views)
