excel graph color
I tried to change the color of a graph in excel.
the graph was created before.
I've got 4 lines and have an array with 4 items connected to Excel_Set_Chart_Colors.vi.
has anyone an idea?
the error text is:
-2146827284
Unknown System Error in Excel_Set_Chart_Colors.vi->Excel Set Graph Colors.vi->ExcelExport.vi
Markus
(3,275 Views)
Hi Markus,
i think you get the error because you don´t insert a graph. If you want to change only the color, then you have to set some internal used refereces, which will be created if you use the "Excel insert graph.vi".
Mike
(3,270 Views)
Hello Mike,
look at the attachment. I created a graph. Or am I wrong?
Markus
(3,266 Views)
Hi Markus,
yes you are right, but i thought you do not because i get the error you said only if i try to change the color without creating a new graph. Can you upload your code?
Mike
(3,251 Views)
Hello Mike,
in the attachement there is my vi. I modified the vi. But the error is existing.
markus
(3,238 Views)
Hello Mike,
I tried the vi running without a template on the input and it worked.
markus
(3,230 Views)
Hi Markus,
if i use your example and i connect a template file, then it works for me.
Mike
(3,225 Views)
