excel easy table
When I use Excel Easy Table.vi to export my data, the double numeric values are losing precision. For example, 0.0054 to 0.005 and 0.0085 to 0.009. Is there anyway to stop this occurence?
CLD Certified 2014
Message 1 of 10
(5,958 Views)
what is excel easy table?
Could you please post the vi.
Grugh
Grugh Mike
Success is Everything !!
Message 2 of 10
(5,955 Views)
It's part of the Report Generation Toolkit.
How are you converting to the string data that is the input? What format string? It's probably something as basic as using %.4f.
Message 3 of 10
(5,950 Views)
I have a 2D array of DBL data. The font (cluster in top left of picture) has no precision control.
CLD Certified 2014
Message 4 of 10
(5,947 Views)
Accepted by ADrexelDragon
Forgot you could wire numeric data directly to the fnction. Buried deep in one of the subVIs, the conversion to string is done. So, instead of modifying the subVI, just convert the 2D dbl to a 2D string array before passing it. Number to Fractional String will work.
Message 5 of 10
(5,942 Views)
Worked like a charm! Thank you.
CLD Certified 2014
Message 6 of 10
(5,936 Views)
Hi all,
how can i have access to the Vi ' excel the vi easy table' I use the LABVIEW 201 but can t find it.
best regdrs
Marcy
Message 7 of 10
(5,489 Views)
@marcy2014 wrote:
Hi all,
best regdrs
Marcy
Did you not read in the post above that it is part of the Report Generation Toolkit?
Message 8 of 10
(5,473 Views)
HI Guys
I get Labview Version 2014 but in my Report generation Toolkits i dont have : eXCEL easy Table. How can i get it please ?
Best regards
Message 9 of 10
(5,398 Views)
@marcy2014 wrote:
HI Guys
Best regards
Report Generation Toolkit comes with LabVIEW 2014 Professional.
Otherwise you have to purchase it.
Message 10 of 10
(5,388 Views)
