example 2 channel oscilloscope VI using real signals
I am seeking a 2 channel oscilloscope VI that uses real signals, no the simulated signals that are used by "Two Chennel Oscilloscope.vi" which I found under Examples when I searched for "scope" or "oscilloscope".
I found on an NI website "One_Channel_Simple_Scope.llb".  I think it uses real signals.  I downloaded it but could not run the VI.  When I tried to do so, it did not compile successfully.  The error messages were that several subVIs were not found: DAQmx read.vi, DAQmx timing.vi, etc.  I have LV 8.6 and NI 6221 multifunction DAQ card installed in a standard configutration in a Winows Vista environment.  Do I need to set a path variable to tell LV where to find these VIs?
Thank you.
(11,003 Views)
Accepted by topic author WCR
Not a high sampling rate, but this does use L and R sound card inputs for 2 channels:
http://decibel.ni.com/content/docs/DOC-4834
Did you install traditional DAQ drivers and no the newer DAQmx style? That may be the source of your errors.
-AK2DM
(10,998 Views)
The program you suggest looks excellent.  I downloaded it and got the same errors as previously reported: "can't find DAQmx ....vi".  I don't know the answer to your question about whether I installed traditinoal or modern DAQmx routines.  Modern I think.  Whatever the default was is probably what I did.  And I have discovered that other VIs I have written that used to work no longer work, for similar reasons.  (Been a few months since I used Labview.)  Maybe some files got deleted that shouldn't have been.  I hope I don't have to reinstall Labview.  Is there some place I should look for certain things, and if so where and what?
(10,985 Views)
Try installing/reinstalling the DAQmx drivers from the device driver DVD.
(10,966 Views)
