Using thresholding correctly
Hello everyone. I've been trying to do some vision stuff with LabVIEW's VDM and was having trouble with contrast, so I decided to try thresholding the image and working with the modified image. I can't figure out why my threshold function isn't working correctly. I've included a ss of the block for my VI for those of you without LabVIEW2009.
Thanks.
Using LabVIEW 2009 on Windows Vista
(3,137 Views)
which format of the image are you trying to threshold. If you want to threshold an RGB image (JPG for ex). Then you have to convert that into a grey scale image (Extract color planes). If you want to threshold a RGB image directly then use "Color thresholding"
(3,110 Views)
