event structure
Hola quisiera que me ayuden en como utilizar detalladamente la structura event, tengo el labview 8.6. es que no puedo agregar eventos, como el mouse y teclado.
gracias de antemano
(3,551 Views)
Google Translate:
Hi I would like to help me in detail how to use the structura event, I have labview 8.6. I just can not add events such as mouse and keyboard.
thanks in advance
Answer: You will need to be more specific. Are you referring to mouse/keyboard events for specific controls/indicators, or general mouse/keyboard events?
(3,549 Views)
Not sure...
Does the basic version of LV allow dropping and configuring event structures?
I am sure they can be used but I seem to remember the could not be dropped on the diagram or configured.
Still not sure...
Ben
(3,522 Views)
The base version does not give event structures as an option.
Tim
GHSP
(3,510 Views)
Just to emphasize, here goes the comparison board for each version of LabVIEW.
 https://www.ni.com/en/shop/labview/select-edition.html
There you can see that event structure is not available in Base version.
jcarlosmc27, could you just confirm that you are using Base version? If it is the case, you can't use event structure. If you are using any other version, you can find information in ni.com web site. Here goes some links with information about event structure.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/event-structure.html
https://www.ni.com/docs/en-US/bundle/labview/page/event-driven-programming.html
https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html
Let us know if you have more problems.
Rodrigo Schneiater
NI Brazil
If this information was useful, please click in the 'KUDOS!' beside.
(3,453 Views)
