event handling
Well I find the message displayed when the code is run rather aggressive!
Esp. since we volunteers try to help you, and such a message when we want to look at your debug code is rather annoying.
Ton
My LabVIEW Ideas
Message 21 of 34
(2,150 Views)
Hi Ton,
I can totally understand your statement. Just because the code is annoying, I created a situation similar to the portion of my code I am having a problem in rather than posting the whole code. The situation and problem I am having in my original code is as follows:
I want to write 1 to the serial port at an interval of 5 minutes repeateadly and anlyze the values I acquire on the graph again through the same serial port.
I tried using the for loop and a wait block in the code as suggested by my friend Anna. However, when I do so, after a specied time inputed to the wait block, 1 is written to the serial port for N number of times (for loop input) without creating an subsequent delay of 5 minutes.
In order to give a check I tried the attached code which works fine. I do not know why does the same logic not work in my code.
Mozill
Message 22 of 34
(2,143 Views)
Hi Anna,
I am stuck in a serious problem I am figuring out since last few days. Could you help me please? The problem is as follows:
I am requesting temperature and humidity from my pic controller through rs232 port. So, I have to write 1 (for temperature) and 2 (for humidity) to the serial port. I have four options-
1. requesting current temp.
2. Requesting Current Humidity
3. Requesting temperature for a given time period, and
4. Requesting Humidity for a given time period.
I have set-up the code for that. The first two options are working fine. However, third and forth have a problem. Instead of writing to the serial port after a give time interval, the values are writen one after another without any time lag. For the very first time, the program waits for a given interval; but thenafter, it writes to the serial port without giving any time delay.
The problem I am describing is in the case 2 and 3 of the main case structure. If I can find the problem with the programming in case 2, then case 3 will run fine too.
I am attaching the code for your reference. Thank you for your time.
Mozill
Message 23 of 34
(2,122 Views)
Hi Mozill,
I noticed in your case statements for the repetitive measurements (cases 2 & 3) that you are doing multiple serial writes, but not multiple serial reads.  You need to have a read for every write in your code for it to get the data you'd like.  I hope this helps!
Anna M.
Message 24 of 34
(2,101 Views)
Hi Anna,
I am following all your instructions and they are working perfectly fine. However, I would like to know one more thing. My temperature readings as calculated by the formula node are fed into the waveform chart. Now, I need to save this data to the excel sheet. I went over the 'write waveforms to file.vi', but the data coming out of the formula node is not any array. How do I perform my job. Also, I need to save the humidty readings in the same excel file.
Any suggestions are appreciated. Thank you for your time.
Mozill
Message 25 of 34
(2,063 Views)
Hi Mozill,
It looks as though the data that you'd like to write to an excel file is one-dimensional, in which case, you might not need to use the "Write Waveform to File" vi. You could simply try "Write to Spreadsheet File" vi. This will accept both 1-D and 2-D data but is ideal for recording a long array of data.
If you'd like to write multiple arrays of data to one excel file, you will first need to combine the data into one 2-D array. You can then wire this to the Write to Excel File vi where it will record multiple columns of data.
Cheers,
Emilie Elizabeth
Message 26 of 34
(2,034 Views)
Hi Emilie,
Thanks for a prompt response. I changed my mind. I will rather make two different excel files. One for the humidity and other for the temperature. But I wanna make a 2-D array in the sense that I will log the time as well as the temperature/humidity values. In order to do so, I made the following vi (attachment). But, unfortunately it does not work. I tried probing but I do not see any value at the output of the build array function. I am able to get values plotted on the graph though.
Mozill
Message 27 of 34
(2,029 Views)
Hi Elizabeth,
I made some changes to my program as shown in attachment below. I am able to get the values. I need the time, date, and data to be in three different columns for each iteration. Right I am able to get the output as shown in 'result' file. I want tabs between time, date, and data; but I am not getting that.
Any help is appreciated.
Message 28 of 34
(2,014 Views)
Hi Elizabeth,
Any help is appreciated. Thank you for your time.
Mozill
Message 29 of 34
(2,014 Views)
Hello Mozill,
You might try simply transposing the 2-D array before you wire it to the Write to Spreadsheet vi.
Cheers,
Emilie Elizabeth
Message 30 of 34
(1,998 Views)
