Giving a specific path to the reading from excel application
Hello, i want to know there is a way of giving a specific path to an application (reading from excel sheet) without all the time getting to enter the path? if someone could help. i'm using labview 8.0
Tchaou
(2,694 Views)
you could just use a path constant. Drop a path constant on the BD and right click on it and select browse and then find the file you want.
Joe.
"NOTHING IS EVER EASY"
(2,687 Views)
hi  Jhoskins,
thank you for your reply it works.
Regards
(2,664 Views)
