event does not work with while loop and it stop function the VI
hello everybody,
I have a problem , I uses 3 loops ,each loop do a function , first loop acquire the data and display it , seconde take data and save it in .txt and the third loop for event to action somme function , the problem that the third loop doesn't work and if I push of button's event the Interface blocked.you find my vi here.
(2,998 Views)
That's not a VI, just a truncated blurry code image.
Your upper loop can never stop because a FALSE is wired to the stop terminal.
That loop can only go to the next iteration when both events have fired, so most likely never, especially if they are configured to lock the front panel.
Attach your actual VI. Still, you probably should start with some simple tutorials about dataflow.
(2,991 Views)
Thanks for replying,
I knew but I don't want to stop the loop , I want working all the time to action the event,however the loop doesn't work ,the iteration still in 0
(2,971 Views)
Accepted by ouassim.ahmadi
(2,968 Views)
Why do you have two event structures in your loop? You definitely need to read up on how to use event structures - and perhaps some basic tutorials on dataflow. Your loop will not iterate until both of your event structures have fired.
(2,948 Views)
