cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
eula file error when building distribution
Resolvido!
Ir para a solução
I'm trying to build a distribution (package installer) but am coming across an error. It's a very long error and I've attached screenshots of it it in several snips (possibly overkill).  I am using LabVIEW NXG.
A couple things to note:
- The project executable builds successfully, but the package installer fails
- I have been able to successfully build a package installer for this exact project several times before (even as recently as 7-10 days ago).  I just made some changes and need to build a revised version.
- The project files have been moved around probably more than they should be - maybe this has something to do with it?
I currently have a support ticket being worked on but if anyone in the community has suggestions they would be greatly appreciated!
Thank you in advance!
Mensagem 1 de 2
2.626Exibições
Solução
Aceita pelo autor do tópico michelleann
Please disregard this post - seems like I can't delete it?  I updated NI Package Manager and was able to successfully build the distribution.   Problem solved!
Mensagem 2 de 2
2.592Exibições
