ethernet
Hi all,
i´ve just read the possibility of using Ethernet deterministically  (time-triggered networks) with the Labview 8. Is there any available example about it ? What hardware is required for it?
Thanks in advance. Regards,
e.c.
(3,061 Views)
Have you read the article Using Time-Triggered Networks to Communicate Deterministically Over Ethernet with the LabVIEW 8 Real-Time Module ?
Basically, you need LabVIEW RT and a dedicated second network. QUOTE: "With the time-triggered network, two or more LabVIEW Real-Time PXI or PC targets can transfer data deterministically over a private Ethernet network using off-shelf-network interfaces"
(3,047 Views)
