error with application
all HI !
 vi created in version 8.6. Then he opened in 2010, the application of LV work, but when creating an application gives the following error ошибка.JPG:
full text error:
An error has occurred. Expand the Details section for more information.
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at Invoke Node in AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Method Name: Linker:Write Info To File
 what to do ?
thanks !
(3,324 Views)
Have you tried perhaps trying to mass compile your vi or vi's in 2010 before trying to build them into a 2010 application?
(3,278 Views)
yes
(3,266 Views)
Would you mind posting your LV 8.6 vi and any subvis you are including in the build specs so I can try to reproduce the error?
(3,250 Views)
That reminds of a bug with VI server in a disable structure i had, but it's probably not related. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,235 Views)
