error sending command
I am trying to opem my program Labview2014, but, I find a problem when I try to open it.
One error appears saying: "Error sending commnand"
How can I solve it?
Could you help me please
Best regards
Message 1 of 16
(6,838 Views)
Hi 99,
How can I solve it?
How do you open a program (aka executable) with LV2014?
Are you trying to open a LabVIEW project?
Can you attach that project?
When does that error pop up? Already when opening the project?
To solve that problem you need to debug your project and its VIs…
Generic advice: provide as much information as possible to allow us to help you!
Message 2 of 16
(6,828 Views)
Hi GerdW,
Thank you for answering me.
I attach the problem and the program.
Yes I am trying to open a labview project, but I also try to execute the program to see if the problem is only with that project or if it is in general. And I have seen that I can´t open neither the project nor the program. I find the same problem when I try to open any program.
Message 3 of 16
(6,817 Views)
No problem opening the VI here, although sub-VIs are missing.
Do you get that message when you open the VI from the project?
"I find the same problem when I try to open any program."
By "program", do you mean VI?
Certified LabVIEW Architect
Message 4 of 16
(6,811 Views)
Hi 99,
the same for me: I can open your VI without problems (apart from missing subVIs).
Why don't you simplify the VI similar to this:
Message 5 of 16
(6,797 Views)
First Google hit: "labview error sending command"
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFRiSAM&l=en-US
Does any of that help?
Bill
CLD
(Mid-Level minion.)
Message 6 of 16
(6,759 Views)
Hi billko,
Thank you for the link,
I tryed to open Labview to open after the project from the program, but I can´t neither open the program
Message 7 of 16
(6,730 Views)
Hi 99,
@labview99 wrote:
Hi billko,
Yesterday someone told you to write "tried" instead of "tryed": take atleast suggestions for proper English when you don't take suggestions for your LabVIEW code…
What did you open? In which order? Where do you fail?
If you fail with opening the VI: have you taken an older version of your code from your SCC (source code control) tool? (Or even a backup of an older version of your code?) Does that older VI version "open"?
Message 8 of 16
(6,727 Views)
Hi GerdW,
I fail opnening just the program. I can´t open the program
Message 9 of 16
(6,724 Views)
Hi 99,
which "program"? LabVIEW IDE? Project? (Specific) VI? Any other executable?
Message 10 of 16
(6,719 Views)
