error permuting matrix rows
Hi
Ive tried to create a VI which randomly permutes rows of a matrix (the matrix is the input/the subvi), but
labview shows me an error, saying that Ive connected terminals of two different types - athough both are long.
Can someone tell me, whats wrong with my vi?
I would be greatful.
Mychelle
Message 1 of 10
(5,945 Views)
The terminals are not both long, you're trying to connect an array of long to a long.
Ben
Message 2 of 10
(5,931 Views)
so what exactly (and how) shall I change it?
Message 3 of 10
(5,917 Views)
Here is a way to swap two rows in an array.
Ben
Message 4 of 10
(5,905 Views)
thanks a lot, could you maybe be so kind and upload the VI?I just dont find the same icons for the
array methods you used (maybe due to different labview versions?).
thx
Message 5 of 10
(5,887 Views)
..sorry, I was first using firefox and so didnt see, that you can use the snippet..
Message 6 of 10
(5,880 Views)
 The image above is a snippet and contains embedded LabVIEW code. Simply download the image and then drag it into the diagram. It will turn into runnable code.
(EDIT: Ah, I see you noticed. Anyway, "index array" is resizeable, so there is no need for two instances as in Ben's example.)
Message Edited by altenbach on 02-20-2010 02:13 PM
Message 7 of 10
(5,878 Views)
If you have a newer version of LV,  wouldn't it be cleaner to use some of the newer memory structures like in place element and swap values?
Message Edited by Ravens Fan on 02-20-2010 05:27 PM
Message 8 of 10
(5,867 Views)
 The OP want to swap entire rows in a 2D array. The in place element structure currently only supports single elements.
Message 9 of 10
(5,858 Views)
You're right.  I failed to notice that the wire coming out of it was thin as in scalar.
Message 10 of 10
(5,850 Views)
