03-20-2008 01:21 PM
03-20-2008
01:28 PM
- last edited on
12-29-2024
04:54 PM
by
Content Cleaner
Hi cmtay,
you can:
- right-click any function that uses error clusters on their lower left/right corner and select create->control/indicator/constant
- get already pre-defined error-clusters from the "Array,matrix&cluster" palette
- make your own cluster: get an empty cluster (see first item) and put a numeric, string and boolean into the cluster...
Or you get the introductional courses for LV![]()
