error in, error out clusters.
Dear all,
I am new user for Labview software. I try to create a Visa Configuration Serial Port but, the error occurred, message as:
"You have two or more cluster data types wired together, but the clusters have different kinds or numbers of elements.
Cluster Cluster 2, a cluster of 1 element, conflicts with cluster error in (no error), a cluster of 3 elements."
My cluster include the function of:
1) boolean Properties
2) Numeric Properties
3) String Properties
Q: how to create these 3 function in cluster?
(3,347 Views)
Hi cmtay,
you can:
- right-click any function that uses error clusters on their lower left/right corner and select create->control/indicator/constant
- get already pre-defined error-clusters from the "Array,matrix&cluster" palette
- make your own cluster: get an empty cluster (see first item) and put a numeric, string and boolean into the cluster...
Or you get the introductional courses for LVSmiley Wink
(3,346 Views)
