02-17-2010 09:19 AM
LabVNC is running in my Server pc. When I am trying to connect from the web browser of client pc, an error message window is generates in the server.
and the labVNC crashes. the error message is " LabVNC server for win32 has encountered a problem and needs to close"
Please anyone help me in this regard..
02-17-2010 10:39 AM
Since LabVNC is 3rd party, you will probably need to get support here: http://jeffreytravis.com/lost/labvnc.html
Are Remote Panels a possibility? If so, you should consider using them as an NI supported alternative to LabVNC.
02-18-2010 06:53 AM
Thanks a lot.
But as far as I know there is a liscencing issue in LabView remote pannel..otherwise that was ok for my purpose.
I have downloaded LabVNC from http://jeffreytravis.com/lost/labvnc.html. But didnt understand what did you mean bt 3rd party support..
Would you please explain?
02-18-2010 09:03 AM
Third-party means a company other than NI (first-party) has provided you (second-party) with the tool that you are using. In other words, you should contact jeffreytravis.com.
02-18-2010 03:59 PM
