error handling
 I have an event case that handle many stacked sequences. How do I connect the error (if any) from any sequence out to "OR" with my Stop button (of the while loop) in case of an error occured ?
Message 1 of 8
(3,649 Views)
Hi dphan,
what code have you already?
Ton
My LabVIEW Ideas
Message 2 of 8
(3,642 Views)
Connect your error( it is a cluster) wire to clusters>>'unbundle by name' function.
Choose the 'status' which is a boolean component and wire it to your 'OR' function
Look at attached pic
Hope this helps.
Dev
Message 3 of 8
(3,641 Views)
Hi Ton,
I'm using LV 7.0.
DPhan
Message 4 of 8
(3,605 Views)
Hi Dev,
I tried the same logic already but I could only connect 1 error status out from 1 sequence frame. What if I want to connect each error status going tru each sequence frame and event case. The error that I had was multiple assignment to tunnel. See attached vi.
Dan
Message 5 of 8
(3,600 Views)
Here is the vi.
Message 6 of 8
(3,599 Views)
A sequence structure is not t all like a case statement where you have a single exit tunnel for all cases. What you are attempting to do is the same thing as wiring four separate controls to a single indicator. That simplu doesn't work. I have no idea why you want to use a sequence structure in the first place. With proper error in/error out handling, it's simply not necessary. However, if you wanted to keep it, I would suggest a modification like the attached with sequence locals. I used a delay function to simulate some code that has error in/error out connections and I forced an error in one of the sequences. I moved the stop button to an event where it belongs and set the value (signaling) property if an error occurs. If the code in each sequence is done right, the first error should propagate through. If there is code you do not want to execute if an error condition exists, put a case statement around the code and wire the error in to the case selector. This will create 'Error' and 'No Error' cases.
Message 7 of 8
(3,588 Views)
Dennis,
Thank you for the modified version with the time delay. That was exactly what I wish to do. Thanks for your help.
Dan
Message 8 of 8
(3,576 Views)
