error code 1003 upon attmpting to run fpga VI
I am attempting to run a VI from an existing project, and I keep getting error 1003 when I attempt to run the VI (previously, I had no problem running the VI).  I tried the forced compile (it compiled successfully), but I still obtain the following error:
An internal LabVIEW FPGA Module error occurred at the following stage:
“Download and/or Run”.
Error Code: 1003
So naturally, I attempted to open the DownloadAndRun_cRIO vi that it pointed to and it seem to hang up on searching for the NRioSrv.dll.  I only mention this because, it was searching for this same file (and couldn’t find it) the first time I noticed the problem when opening the FPGA VI.  I opened MAX explorer to see what I could see.  The cRIO device connects OK, but under Devices and Interfaces I get a NI_RIO Error citing error code 52003: “and unexpected software error occurred”.  Any ideas?
(4,391 Views)
What version of the NI-RIO driver do you have installed? The 52003 error can be caused by a major known issue (CAR 71093) in older versions of the driver. In any case it would be a good idea to make sure you are using the latest NI-RIO driver.
Hunter
(4,365 Views)
I am having almost an identical error. When I attempt to compile my FPGA Vi it runs through the compilation process until the very very end then says : Error 1003 and points to several internal VIs which it claims are unexecutible. These Vis are intrinsic to labview and i am unable to view their block diagrams. I belive we are both having the verry same issue and i would like to help very much. FYI i am using labview 2009 with NI-RIO 3.4.0 and a cRIO - 92014, while trying to impelement the new movieMED AF-1501 anolog frame grabber.
Thanks in advance,
Carter
(4,052 Views)
Can you compile any FPGA VIs? Try opening a shipping example from LabVIWE FPGA and compile it using the default settings. This will tell use if the problem is with your code or ouy software set up.
(4,032 Views)
