error code 10 at create folder
And yes, you said something about keep both files and then create a new folder a1.
Then, in the case where 'Keep both' option is executed, see the iamge attached.
Freelance_LV
TestAutomation Consultant
Message 11 of 16
(1,586 Views)
To Freelance LV
Thankyou for your help, my problem has been solved for now and yes i will post the new query in new post and will look forward for your help and guidance in future also.
Message 12 of 16
(1,581 Views)
  1. You should not be hard-coding paths (such as starting paths) in code. Provide a front panel control.
  2. Do not use string functions to build paths. Use the Build Path function, as these are platform-independent.
Message 13 of 16
(1,560 Views)
To smercurio fc
Thankyou sir for your suggestion, as you said that there should not be any hard coding paths( by hard coding path ,do you mean the constant path i am giving) in code actually the starting path is constant in my code and after that different folder are created in that path.
and yes also in some earlier posts i had read this that i should not use string functions to build paths but since in my code i am having issue of error 10 which occurs if the folder is already present and the starting path is always constant so to avoid that error i am using string functions(it becomes very complicated when i am trying to use build path function instead of string) but i am trying to solve the problem and would definately replace string functions with the build path functions.
Message 14 of 16
(1,543 Views)
@Ritu wrote:
To smercurio fc
Is it constant on another machine? What about if the operating system changes? What about if someone else wants to use it, and they want to save the data somewhere else?
Message 15 of 16
(1,533 Views)
To smercurio fc
Yes sir, you are write, we didn't think upon this, Thankyou for the nice sugesstion, i will try to implement what you had said.
Message 16 of 16
(1,530 Views)
