error 7, report generation toolkits do not work after building.
Hallo guys:
one problem. help!
I tried to build my programs with application builder, unluckly builded exe application does no work well as before, i checked some similar post from this forum, and added that NIReprot.llb in my project and rebuild, the problem still takes place, my program append some text, tables, and charts into a word template with that Report Generation Toolkits, but it always gives out error 7 and 'NI_Word.lvclass:new report subVI.vi -> NI_report.lvclass:New Report.vi -> Creat New Report.vi ->...'error information.
is there anyone can give me some clues about this annoying problem.
thanks a lot!!!
Message 1 of 13
(6,203 Views)
Start here
Message 2 of 13
(6,196 Views)
thanks for the reply, i tried this already, add that NIReprot.llb to my program, but does not work.
Message 3 of 13
(6,191 Views)
So you're using LV 8.6 and Report Gen Toolkit 1.1.3?  (Use MAX to verify installed version of toolkit.)  You added the directory to your project and included the .llb as a dynamic vi in Application Builder?
Message 4 of 13
(6,177 Views)
yes, i attached all this library to my project, but does not work. i can not figure out the problem, any idea?
Message 5 of 13
(6,173 Views)
zybear,
Suggest you start a new project and create a simple vi that uses report gen functions the same way you are trying to use them in your app.  Try compiling that into an .exe and see what happens.
Message 6 of 13
(6,160 Views)
When you say "attached all this library to my project", it is not clear whether you answered the question about including the dynamic VIs in your build specifications. See attached image. You will need to select the files in your project and set them to Always Included. Have you done this?
Message 7 of 13
(6,156 Views)
yes, i did this also, added them in my project and rebuild, but it does not help.                                                               Right now i created a test project with very simple report generation function, it works !!!, but i am still do not know why, i will rerange my project, i hope the problem can be solved.
and thanks guys for your advices.
Message 8 of 13
(6,141 Views)
Accepted by zybear
zybear,
Suggest you take the simple test vi and begin adding all the functionality of your original application.  Build it up in stages and test at each stage.  Hopefully this will help you identify the problem.
Message 9 of 13
(6,138 Views)
I am having a similiar problem and tried to do what you suggested.  The .exe program runs in the computer where LabView 2010 is installed but not in another computer that has the LabView 2010 runtime engine.  It is still looking for the path -->\1abvi3w\vi.lib\utility\niReport.llb\Standard Report\NI Standard Report.lvclass and can't find the file.
Message 10 of 13
(5,274 Views)
