05-13-2009 12:57 PM
Hi All,
I'm running a Labview application, and upon starting it gives the above error. If I stop the program at that error it takes me to the block diagram
shown in the attached screenshot. Any ideas as to how to fix this? I can't see the dt signal at the top level.
Sean
05-13-2009 12:59 PM
05-13-2009 01:07 PM
05-13-2009 01:13 PM
Sean,
Suggest you hook up the error cluster and run in Highlight Execution mode to determine exactly where the error is being generated..
05-13-2009 01:35 PM
sean m wrote:Hi All,
Sean
Waveform Data Type
The waveform data type carries the data, start time, and delta t of a waveform. You can create a waveform using the Build Waveform function. or "unbundle" it with the Get Waveform Components function
05-13-2009 01:40 PM
Since the front panel control is a waveform array, you just have to look at what the dt is. A simple breakpoint will suffice.
Since you are apparentlly creating the waveform array in the top level, using probes will let you see the actual data and where the problem is being created.
05-13-2009 01:52 PM
The program is quite complicated so there are many steps that would have to execute in highlight execution mode before I can see what's executing in this vi.
I also tried adding the error cluster, the only extra info I got was that the error seems to come from ma_CheckWaveformTiming.vi.
I can't see the dt variable that the original error is about.
05-13-2009 01:59 PM
05-13-2009 02:03 PM
Looks like a few others replied while I was writing my previous reply. I set a breakpoint on the waveform wire (see screenshot) and when the error occured the waveform seemed to be empty, i.e. did not contain a dt value. Could this be causing the error?
05-13-2009 02:25 PM - edited 05-13-2009 02:26 PM
Of course it is the cause of the error. You need to track down where in the main VI you are creating the waveform array and why at least one element is empty. Did you try to look at the array itself to see if all elements are empty? In the main, put a probe on the input to the subVI!
If the number of waveforms in the array is variable, you should be doing the analysis inside a for loop instead of using a fixed Index Array function.
