error 2 occured at system exec.vi
Dear forum users,
I have a Frotran exe in my labview code which worked fine before. Recently I got this error message below while running my vi. I remember getting this once before but after rebooting my PC the problem vanished. Now even rebooting the PC I still get the same error. I have attached a screenshot of the error. Please help if anyone knows how to deal with this or guide me if this issue have been encountered before. Thank you.
Error 2 occurred at System Exec.vi. Command was "w.exe"
Possible reason(s):
LabVIEW:  Memory is full.
NI-488:  No Listeners on the GPIB.
Ashvin
(3,265 Views)
Hi Ashvin,
Have you updated your version of LabVIEW recently? It could be an issue with the LabVIEW 2010 compiler. Also, this problem can occur if there isn't a large enough contiguous memory space to load the VI. I would suggest looking through the article below to see if it helps at all.
http://digital.ni.com/public.nsf/websearch/C3C516C11184AF3F862571B5006B46E1?OpenDocument
Best Regards,
Chris
National Instruments - Tech Support
(3,253 Views)
Hi Chris,
Thank you for your advice. I'm not an expert in Labview but  I will try to implement what is written in the article. Your help is much appreciated and will let you know if I have been successful.
Ashvin
(3,243 Views)
