error 1167 from serial write
I'm getting an error code of 1167 after a serial port right. I'm actually writing to the parallel port using the attached vi. The vi works on another machine. Anyone got any ideas what this error means?
cheers
Nick
(3,286 Views)
Hi Nick,
Are you trying to write to the parallel or serial port?
The "Serial Port.vi" that you are using is intended for the serial port. You are trying to wire a parallel port reference to it.
Which version of LV are you using? In LV6.x & LV7, it is recommended to use the VISA functions to communicate with through the serial port.
If you want to communicate to the parallel port, I recommend that you use the "In Port.vi" & "Out Port.vi". They are located in the Functions Palette under "Advanced" and "Port I/O".
They are really simple to use. To write to the parallel port, simply use the Out Port.vi and specify the address (ex. 0x378) and wire in the values for the data bits.
An example of this can be found in LV7, under Search Examples, Par
allel Port.
I suspect the error message you got indicates that the address value is out of range.
I got the following message when I ran your vi.
"VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system."
-JLV-
(3,286 Views)
This is most likely an VISA issue.
Mkae usre the port is defined in the VISA ini file or use MAX to check same.
This code works fine on the WinME machine I am using with both LV 6.1 and LV 7.0.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(3,286 Views)
