error 1097
Hello!
I'm trying to run lv_WriteRealtimeDacData.vi the program is quite easy
Spoiler
But when I'm running it there's an error 1097 message, I'm triying to configure call library fuctions and looks like the problem is in .dll file (The function name specified for this node cannot be found in the library. Right-click the Call Library Function node and select Configure, then choose the correct function name.) The right file is in the system folder, and I choose the right path for it, any ideas what's the key for this problem? I'm actually quite new to labview, please be patient)
(2,718 Views)
There are lot of discussions regarding this error code and most of the problems are solved. Search here and post if you still find problems.
Mathan
(2,712 Views)
