06-07-2005 12:22 PM
06-07-2005 01:00 PM
06-07-2005 02:50 PM
@Dennis Knutson wrote:
NFRD is Not Ready for Data and NDAC is Not Data Accepted. These are handshake lines on the GPIB bus. NFRD indicates that an instrument is ready to receive a message and NDAC indicates whether an instrument has accepted a message. You say you are using the HP34401A to model the multimeter. Does that mean you have a different model connected? If you do have the correct model connected, did you select the VISA Resource Name to match what is actually detected by MAX or did you leave it as the default. If you right click on the VISA Resource Name arrow, you will get a list of all valid names.
06-07-2005 03:05 PM
