Can load image from file using LabVIEW and display on IMAQ graph?
I dont have IMAQ Vision for LabVIEW on my computer. Is it possible to load image file and display on an IMAQ graph?
Thanks!
(3,129 Views)
Hey werwr,
In response to: "I dont have IMAQ Vision for LabVIEW on my computer. Is it possible to load image file and display on an IMAQ graph?"
As of right now, in order to read an image from file, you actually do need the IMAQ Vision software. The IMAQ driver without the Vision VI's will allow you to collect images from a framegrabber, and it will allow you to save those images to file. But the function that allows you to read an image from file does require the Vision VI's. Once you have the VI to read images from a file, you will be able to display the image on an IMAQ "Graph" or otherwise known as an Image Display.
I hope this helps. Please let me know if you have any further questions.
DJ
(3,115 Views)
