error 1003 internal.llb
I worked with a LabView Project for a while using LabView 6.1. Than I installed at the same PC LabView 7.0 and recompiled everything. I could build applications without any problem over the last 5 months. Two weeks ago I copied my VIs to another PC with LabView 7.0 installed. After having made changes within some days I tried to build an application for distribution I got the 1003 error. I ran masscompile and recompiled the VIs, nothing changed.I reinstalled the LV runtime and did many other things. What can I do to solve that problem? The VI runs in the development environment without any problem.
(3,068 Views)
Hello Andreasl,
Thank you for contacting National Instruments.
Please try the steps listed in the following Knowledge Base:
http://digital.ni.com/public.nsf/websearch/705C2ECA081F3C7986256C0F00559B02?OpenDocument
Make sure all sub-VIs are working properly. Your main VI might run correctly even with a broken sub-VI if the broken VI is not called.
Let me know if this does not help.
Sean C.
(3,068 Views)
Here is a vestigial case of a program that compiles but will not build error 1003. I suspect it is something to do with the mis typing of a strict typedef and a typeder.
How should we send in bug notification
Yours Sincerely
John Brohan
(3,068 Views)
