I want to build an application with an older App.builder(4.0.1). I use LabView 5.0 on Win2000 and tried to build a simple window with a switch that controls a LED in a while loop. (That means i don't need any big resources). I followed the instruction manual of the app.builder, and after selecting/naming a "xxxx.exe" and starting the building process, i get the message "Building not successful. Resource not found".
My path where the desired vi/llb is saved, is
C:\Program Files\National Instruments\LabVIEW
Could that be the problem, or is it a version problem, or is something others wrong?
Thank you,
Markus
