error 100 building installer in labview 2015
The exe can build successful,but the installer build failed.
Error details:
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error -1 occurred at CDK_Utility_GenerateErrorCluster.vi -> IB_MSI.lvclass:Build.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-1) or for its hexadecimal representation (0xFFFFFFFF).
The following errors and warnings were recorded during the build:
Error:
*** Abort requested.
Details:
Done building deployment
Code:
-100
undefined
(2,643 Views)
Accepted by topic author qingge
So do you have the installer for VISA 15.0.1?  If not, you need to get it ...
(2,591 Views)
hi Bob,
      I have the Labveiw installer and the NI device drives , so  i uninstall the labview and reinstall Labview and the drivers.
Now,it works.Thanks for your help.
(2,566 Views)
