equivalent of visual Basic static variable in LabVIEW
Hi all!
I am doing a project where I am counting the values. After i Close/Stop the program I want the value to be intact and continue with the last value.
I know this in Visual Basic. By using the Static variable we can retain the value even we close the program.
Kindly help..
Srikanth Chilivery,
(3,420 Views)
I have trouble believing that a static variable retains its value after the program is terminated.  Once the program is released from memory, that static variable is gone.  If you want to retain a value between closing and opening an application, you have to save it to disk in some way.
Are you working exclusively in the LabVIEW IDE or are you running EXEs?  It sounds like you probably just want to use a Functional Global Variable/Action Engine.
(3,412 Views)
Actually I am doing the project in LabVIEW...
I need a way to store a value (counter) Even if i stop/close the VI.
Srikanth Chilivery,
(3,402 Views)
As I already stated, you need to save the value to a file.  Upon running the VI again, read the value and store it whever you are storing it now.  On close, save the new value to the file.
(3,395 Views)
Accepted by windows
I program in Visual Basic. What you write is simply NOT true. Once you close a program everything associated even static variables is gone.
Do as crossrulz suggests.
(3,372 Views)
I found my mistake...
I used another method to design my program..
Thanks for Helping...Smiley HappySmiley HappySmiley Happy
Srikanth Chilivery,
(3,351 Views)
